Trace wiring and correct wiring fault on aileron trim indication on ES. Remove LH fairing and test LH fuel sender. Still not reading correctly. Drain tank and remove sender unit and test - OK. Install again and test - open circuit. will have to replace.
On engine run up before flight - RH mag dead. Cancel flight.
