Remove hatched areas as per plans. Do bending as per degrees indicated using bending blocks. Attach stiffener, support bracket, clip and air dam to the left air ramp, match drill, de-burr and rivet as per callouts. Drill pilot hole for prop governor. Prepare CB1002H bracket, remove hatched area and measure and drill holes as per plans.
