Remove LH wing panel, RH set and side panel. Do roll servo wiring and perfom all ground testing and setup. found pitch operating in reverse. Remove AP and add link in connector. Also connect static number 2. Do flight test and adjustments.
Change some labels on panel. Extend wing walks to the back and add wing walk material to the steps.
