Brief Description: Install aileron trim spring brackets
With neutral aileron position, mak center of electric trim arm on the aileron pushrod. Remove aileron pushrod, drill holes as per callout and rivet WD1017B-L WD1017B-R to aileron pushrod. Install springs onto brackets and fix to pushrod for later final install. Re-install aileron pushrod.
