Today I also assembled the upper and lower control arm parts - after cleaning out the powdercoat from the tubing and holes. I only mounted the lower control rods today, as I'll nedd to move the gyro outside to raise the mast to connect the upper rods and check how everything links up. Since I have a folding mast, the clips on the bolts will allow me to remove them as needed to fold the mast down, and yet prevent any hardware from leaving the gyro in flight!
