Brief Description: Assembly of Main Gear to Airframe
After all this time, the wheels are finally going to be mounted. I had to lay the frame on its side for the initial work of attaching all the parts to the frame - trailing arm, suspension and main gear arm. Once I got that together, I was able to place the gyro on 1 wheel and tie the mast to the garage door to allow me to work on the left side.
