Date March 09 2019 time 2:00 Pm Aircraft on a 11.5 degree climbing 60 Fuel flow test Test conducted by Giorgio Azzalin Observer Claudia Roman Mina
Left tank filled with 5 gallons . In the thank there was the minimum usable fuel to be determined
Task Time in minutes and sec ( decimals) Fuel in gallons Gallons per hours Notes 1 2.70 1 22.22 Fuel taken after the gascolator and filter before the fuel pump, fuel selector on left tank 2 2.71 1 22.14 Same as task 1 3 2.69 1 22.30 Same as task 1 fuel selector on both right tank empty 4 2.33 1 25.75 Left tank with the fuel pump ON and fuel taken on the right carburetor, no fuel with pump OFF 5 9.00 0.5 3.33 Gravity fuel trough the fuel pump ( off) check valve and to right carburetor fuel inlet 6 0.5 All 5 gallons out of the left tank
Right tank filled with 5 gallons on completely empty tank
7 2.69 1 22.30 Fuel taken after the gascolator and filter before the fuel pump, fuel selector on right tank 8 2.33 1 25.75 Right tank with the fuel pump ON and fuel taken on the right carburetor, no fuel with pump OFF 9 2.30 1 26.09 Right tank with the fuel pump ON and fuel taken on the left carburetor, no fuel with pump OFF 10 9.00 0.5 3.33 Gravity fuel trough the fuel pump ( off) check valve and to left carburetor fuel inlet 11 0.7 4.3 gallons out of the tank ,usable fuel , the unusable fuel is .7 gallons per tank No leaks or was found No debris on gascolator was found Test was concluded at 5:30 PM same day
