Weight & Balance Date 03/13/19 Registration N1960G Builder :Giorgio Azzalin Model :Nando Gropppo Trial Serial#: 00122/163 Datum on the leading edge of the aircraft ( arm measurements taken from this point)
Max Gross weight (lb) 1322.7 CG range (In) 9.4-16.7 Wt. (LB) Arm ( In) Moment In.Lb. Empty Weight /CG
Right Main Wheel 314 -5.75 -1805.5 Left Main Wheel 320 -5.75 -1840 Tail Wheel 63 170.25 10725.75 Aircraft Empty Weight 697 7080.25 Empty C.G. 10.158
