RV10 I-CAVS
Date:  3-29-2020
Manual Reference:  9-B(11) step 3-6
Brief Description:  ELEVATOR rivet the E-1008B Halves to spar on both
Riveted with squeezer the rear spar to the E-1008B halve on the right elevator (bottom skin) together with Lucio. Riveted the shear clips in the right position
Riveted with the squeezer the rear spart to E-1008B halves on the left elevator (TOP Skin).
One rivet on shear clip not good. Drilled out with some difficulties. slightly enlarged hole. Riveted with bucking bar with better result.
RIveted shear clips and gussets to spar
