RV10 I-CAVS
Date:  3-15-2020
Number of Hours:  4.00
Manual Reference:  8-C(12) step 1-2
Brief Description:  HS skin on cradles and cleco structure rivet front
positioned skins in the cradles. clecoed all front ribs to the skins.
started riveting with flush rivets.
Using the rivet swivel set didnt really help setting good rivets. I had to drill out a couple.
Changed to flush-rivet set and it worked better, although i pushed a bit too hard in two spots (skin is slightly deformed around a couple of rivets, but no major dents.
Rivets on the Inspar ribs (AN470AD4-7 and 8) are not very well set. little marring due to the squeezer.
Drilled out a bad rivet with angle drill (not easy to access) and replaced with slightly better results.
CHECK WITH LUCIO on the RIVETS on HS-905 Inspar Nose RIBS.
