RV10 I-CAVS
Date:  3-12-2020
Number of Hours:  0.50
Manual Reference:  8-3 step 2
Brief Description:  HS Bolt Hinge Bracket assembly to rear spar
Consulted torque table on section V (page 5-20)
Determined the friction drag torque on the nyloc nut around 5-6 Inch/pounds
Added the 6In/lbs to the self locking nut torwue value (28 in/lbs) and final torqued at 34 in/lbs.
CHECK IF VALUES ARE CORRECT WITH LUCIO. POSSIBLE SLIGHT OVERTORQUE BECAUSE OF USING THE SELFLOCKING TORQUE VALUES INSTEAD OF THE NORMAL AN365 (20-25 in/lbs).
