Brief Description: ELEVATOR rivet the E-1008B Halves to spar on both
Riveted with squeezer the rear spar to the E-1008B halve on the right elevator (bottom skin) together with Lucio. Riveted the shear clips in the right position
Riveted with the squeezer the rear spart to E-1008B halves on the left elevator (TOP Skin). One rivet on shear clip not good. Drilled out with some difficulties. slightly enlarged hole. Riveted with bucking bar with better result.
