RV10 I-CAVS
RV10
8-3 step 3
HS Elevator attachment bracket fabrication
cut from AA6-187X2X2-1/2 angle two parts
Drilled 1/8" hole in the indicated position.
Trimmed to measure.
Drilled 3/16" holes
Radius all corners 1/8".
After mounting and matchdrilling the holes are right at the limit to the edge.
After consultation with Lucio Castrogiovanni it seems that the fabrication is acceptable.
As i ordered other angles from VANS i consider to refabricate the brackets.
RV10 Home
422
353
