RV10 I-CAVS
RV10
8-2 step 1-4
HS rear spar assembly & Prime
Deburring all parts including lightening holes
Matchdrill holes from spart into doubler #30 drill
Final drill all the other 1/8" holes with #30 drill
Machine countersink holes on spar. Mark holes NOT TO BE Drilled
Final drill #12 wht 3/16" holes in the hinge brackets.
Cleco hinge brackets and final drill#30 into spar.
Scuffed the hinge brackets. Cleaned all parts with EkoClean.
Primed with Valspar Self Etching ZincOxide Primer green
RV10 Home
422
353
