Brief Description: Fuse - Began work on the center section
I started mocking up the center section bulkhead. It's pretty straight forward. The only issue is installing the close tolerance bolts. They seem to be exactly the same size as the hole. I stuck them in the freezer for a while and then I could get them in to ensure the alignment before drilling.
