I finished placing the ribs in the left tank and cleco'ing it together. I cut out most of the stiffeners for the left tank but couldn't find all the stock so I'll need to order more. I put the left tank in place and drilled the root Z bracket and also drilled the edge strip between the leading edge and the tank. Next weekend I'll remove the tank and leading edge skins and drill the rest of the tank to Z bracket locations.
