Trimmed inlet duct to face of foam plug then removed foam from lower cowl. Sanded inlet duct then added 2 more layers of fiberglass to inlet and let cure. Final sanded inlet duct and added seal coat of epoxy resin. Installed oil cooler and filled with oil. Installed fuel and oil lines. Installed breather tube assembly. Installed Surestart ignition booster.
