RV-10 N73GF
RV-10
Finishing Kit
4-22-2023
Aerosport
Cowl pin covers and FAB
Cut cowlings apart at pin cover split lines then installed nutplates per Aerosport instructions.
Test fit covers.
Applied microballon mix to oil door and sanded to fit top cowl contour.
Began fabrication of filter air box.
RV-10 Home
2866
ADAHRS Installation
Aieron Trim Servo
Aileron Control
Ailerons
Aircraft Jacks
COM Antennas
Doors
Elevator Trim Tabs
Elevators
ELT Installation
Empennage Attach
Exterior Painting
41
334
Fairings
Finishing Kit
Flaps
Flight Controls
Fuel Tanks
874
Helpers Hours
Horizontal Stab
Instrument Panel
Modifications
NACA Vent System
NAV Antenna
Pitch Trim Servo Ins
Pitot Probe
Rudder Cable Fairing
Static System Instal
Tailcone
Tailcone Attachment
Transponder Mount
Vertical Stab
Weighing
Wing Attach
Wing Inventory
312
XPDR and UAT Antenna
