Sanded fiberglass strips that were added to inside cowl attach lip on upper and lower cowls. Final sanded upper and lower cowls for fit at firewall. Sanded gelcoat at fasteners then using bright LED lighting inside cowl located and drilled 1/8" holes at fastener points on upper cowl and installed clecoes.
