Cut slot for NLG leg in bottom cowl. Using same method as top cowl fitting centered lower cowl to fuselage, top cowl and spinner. Marked firewall trim line and trimmed lower cowl to firewall as required. Marked side cowling upper to lower split lines on both sides of fuselage for reference to install Skybolt fasteners on firewall side of upper and lower cowlings.
