Brief Description: Brake lines and Flap POS-12 sensor
Installed Aircraft Specialty gear leg flex brake lines and secured with teflon tape and tie wraps. Selected mounting spot for POS-12 flap position sensor. Fabricated slotted bracket to allow for adjustment then mounted to flap bellcrank. Installed and rigged flap position sensor using 4-40 hardware and ball end swivels. Performed ops check on system.
