Brief Description: Brake reservoir, fluid press manifold and PPS
Mounted brake reservoir to firewall. Mounted fluid pressure manifold with fuel and oil pressure senders. Selected mounting location for Vertical Power PPS and installed nutplates as required. Mounted PPS with Vertical Power recommended hardware.
