Cut hole for RH display and installed nutplates. Installed panel and fitted fwd center pedestal carbon fiber sides then using hole finder drilled for attach screws. Positioned center armrest and using hole finder drilled mounting holes aligned with tunnel cover screws. Fitted fuel selector assembly on center armrest fwd flange. Cut valve extension to fit and temporarily mounted to check for proper fit and alignment.
