Installed aluminum panel subframe and checked fit of carbon fiber panel. Cut panel openings for aluminum panel inserts and clamped carbon fiber to sub frame. Trimmed and fitted lower center console and fwd side panels as required. Drilled and installed nutplates in carbon fiber panels as required. Test fit center console to fwd lower console and marked fuel valve extension location in center console.
