Assembled, drilled and debuured yaw servo plate and brackets as required. Primed and riveted nutplates and angles as required. Fabricated two nutplate strips for bracket to bulkhead attachment instead of permanently attaching with rivets to facilitate future maintenance. Installed Dynon tiller arm then installed servo to mounting plate using drilled head hardware for saftey wire. Bolted servo/plate assy in place.
