Brief Description: Baggage floor stiffeners and step install
Backriveted stiffeners to baggage floors. Riveted nutplates to bottom of seat pans as required. Riveted nutplates to upper baggage door seal channel. Final installed steps utilizing TCW Tech bushings. Drilled Vans original mounting hole in tube to fit AN4-20 bolt. Drilled additional hole outboard and fwd in step tube/bushing assembly and installed Vans supplied AN3-20 for added security for step after deburring and priming.
