Marked bend line and bent lower flange on left, center and right sub panels as shown. Clecoed fwd fuse understructure together and final drilled all common holes as indicated. Installed 1044b angle and spacer on center rib. Removed control cable bracket then final drilled nutplate attach holes and screw holes. Deburred and dimpled holes in bracket. Drilled pilot hole in firewall recess box as shown in plans.
