Brief Description: Drilling fwd side skins and under structure
Match drilled holes common between skin, upper and lower side channels and firewall brackets. Final drilled skins to fwd ribs and bulkheads. Final drilled skins to side plates. Match drilled longerons to firewall gussets. Final drilled holes between side channels, rear gussets, and mid cabi decks. Match drilled all remaing tabs on side channels. Removed side skins. Using rudder pedal drill jig match drilled fwd longerons for rudder pedal attach brackets.
