Brief Description: Fwd and Mid side skins and fwd structure
Match drilled mid side skins to under structure and longerons. Drilled gussets to longerons. Trimmed aft end of longerons to proper length. Fabricated wooden blocks to fit upper and lower fwd fuse side channels. Applied twist to side channels as shown in plans. Fabricated clamping block and rolled fwd fuse skins as required.
