Brief Description: Begining work on fuselage center section
Fabricated stiffeners for spar web and match drilled. Assembled and match drilled two sets of mid seat rail supports then match drilled to spar. Match drilled left and right center section bulkheads to spar assy. Countersunk all holes as required. Installed left and right landing gear mounts then match drilled to spar. Disassembled and deburred all parts.
