Using Dynon instructions, located and drilled pitot mount bracket and stiffener angle to skin, rib and spar flange. Temporarily fit pitot probe and installed tubing for AOA and pitot installation then secured as required with adel clamp and tye wrap base. Installed wing wiring and CPC connector for pitot heat controller.
