Brief Description: Installing elevator rod ends and drilling control
Installed rod end bearings and jam nuts in both elevators as indicated. Attached horizontal stab to workbench and attached elevators. Adjusted rod ends as required to allow for proper clearance from aft spar. Using E-bushing provided in kit drilled both left and right elevator inboard hinge points on control horns. Final drilled to 1/4". Deburred holes and reinstalled elevators. Drilled 3/16" hole as indicated in one elev control horn for pushrod attachment. Using wood drill guide drilled other elev bellcrank pushrod attach hole and deburred.
