Brief Description: Match Drilling Brackets to Mounting Tray
Clecoed the trim motor spacer, bellcrank brackets and trim cable anchors to mounting tray and match drilled. Countersunk holes in spacer as indicated. Countersunk #40 holes for nutplates in mounting tray. Match drilled trim servo link arm and bellcrank. Dissassembled, deburred and primed all parts. Riveted belcrank brackets, trim cable anchor brackets, nutplates and trim servo link arm as indicated. Installed trim servo, bellcrank and link arm assembly.
