Brief Description: Static System Plumbing Routing and Ports
Positioned Dynon static ports and match drilled to skin. Fabricated angle plate from .063 sheet and match drilled to F1007 bulkhead frame and temporarily mounted 3 ea. Y splitters for AOA, pitot and static connections for dual ADAHRS units. Fabricated 2ea. L-bracket standoffs and match drilled to upper skin center stiffener for static line plumbing to be installed.
