Trimmed and installed RH wing tip. Match drilled to skin. Removed and deburred skin and tip. Drilled and countersunk tip for nutplate attach holes and installed nutplates. Countersunk nutplate attach holes for #6 screw dimples. Dimpled skin for #6 screws. Fitted and drilled tip rib as required. Riveted both LH and RH trailing edge tip ribs to tips. After riveting applied epoxy resin mixture to both tip ribs to give more finished appearance.
