Brief Description: Stall warning cutout and dimpling
Clecoed stall warn access hatch doubler in place on LH wing as shown. Match drilled holes as indicated. Final drilled #40 nutplate attach holes in doubler. Marked skin and removed hatch area as required. Filed and deburred. Deburred access hatch and dimpled for #6 screws. Dimpled doubler as required. Cut out and deburred slot for stall warning vane. Dimpled the W1008-R splice rib for stall vane switch mounting nutplates. Dimpled tank splice strips, J stiffeners and ribs as required.
