Brief Description: Front spar doubler riveting and rib prep
Riveted together the front spar, caps, doubler and spar attach brackets. Modified HS-1004 inspar ribs to allow clearance for stringers. Placed 9 degree bend as required in flanges of both inboard inspar and nose ribs. Deburred all inspar and nose ribs. Fluted flanges as required to staighten. Clecoed all nose and inspar ribs to front spar and match drilled.
