Finished sanding lower cowl inlet and adjusted gap between FAB and inlet duct per FAB instructions. Trimmed fwd air ramps and fwd cylinder baffles to inside edge of cowl inlets. Trimmed and installed fwd center baffles and nutplates. Riveted prop governor cable bracket and vent flange with screen to LH air ramp. Riveted side cylinder baffles to both fwd air ramps. Fabricated conical gussets for both inlet ramps and riveted in place. Began trimming baffles for proper fit to upper cowl per plans.
