Brief Description: Wing root work, fuel lines and vent lines
Fabricated and installed fuel feed lines per plans. Fabricated and installed fuel vent lines with negative pressure relief valves in case of external vent blockage. Trimmed and test fit upper wing walk spacers. Selected wing root connectors for wiring, coax and pitot/aoa lines then drilled and added holes as required in fuselage root area.
