RV-10 N73GF
RV-10
Modification
Lower Com antenna doubler install
Using aluminum sheet fabricated spacer and doubler for lower com antenna mount.
Match drilled to existing holes in rib flange and rear spar.
Added fasteners as required.
Test fit com antenna.
RV-10 Home
2866
ADAHRS Installation
Aieron Trim Servo
Aileron Control
Ailerons
Aircraft Jacks
COM Antennas
Doors
Elevator Trim Tabs
Elevators
ELT Installation
Empennage Attach
Exterior Painting
41
334
Fairings
Finishing Kit
Flaps
Flight Controls
Fuel Tanks
874
Helpers Hours
Horizontal Stab
Instrument Panel
Modifications
NACA Vent System
NAV Antenna
Pitch Trim Servo Ins
Pitot Probe
Rudder Cable Fairing
Static System Instal
Tailcone
Tailcone Attachment
Transponder Mount
Vertical Stab
Weighing
Wing Attach
Wing Inventory
312
XPDR and UAT Antenna
