RV-10 N73GF
RV-10
N/A
Tunnel access panels
Marked and cut out fwd fuselage ribs for access panel installation.
Fabricated 2 ea. doublers and access panels from same material as fwd fuselage ribs.
Marked rivet holes and #8 screw holes then match drilled to ribs as required.
RV-10 Home
2866
ADAHRS Installation
Aieron Trim Servo
Aileron Control
Ailerons
Aircraft Jacks
COM Antennas
Doors
Elevator Trim Tabs
Elevators
ELT Installation
Empennage Attach
Exterior Painting
41
334
Fairings
Finishing Kit
Flaps
Flight Controls
Fuel Tanks
874
Helpers Hours
Horizontal Stab
Instrument Panel
Modifications
NACA Vent System
NAV Antenna
Pitch Trim Servo Ins
Pitot Probe
Rudder Cable Fairing
Static System Instal
Tailcone
Tailcone Attachment
Transponder Mount
Vertical Stab
Weighing
Wing Attach
Wing Inventory
312
XPDR and UAT Antenna
