RV-10 N73GF
Date:  5-13-2017
Number of Hours:  10.00
Manual Reference:  Modification
Brief Description:  ADAHRS Mounting Tray
Fabricated ADAHRS mounting tray from .063 aluminum angle and sheet.
Selected suitable location for ADAHRS/Magnetometer units as per Dynon's recomendations.
Fabricated 2 ea. horizontal braces from .063 3/4" aluminum angle and positioned directly behind the F-1007 frame and matchdrilled to longerons and bulkhead for #10 bolts.
Fabricated mounting plate from .063 sheet and match drilled to fwd and aft braces for #4 rivets.
Fabricated 2 ea. vertical struts from .063 1" aluminum angle and match drilled to upper skin stiffeners and aft brace.
Utilized Dynon's Secondary ADAHRS Mounting Plate Kit P/N 102532-000 to allow secondary unit to be piggyback mounted as pr Dynon instructions.
Dissassembled, deburred and primed all parts.
Installed #8 aluminum rivnuts to ADAHRS mounting plate to prevent interference with magnetometers.
ADAHRS viewing aft
ADAHRS viewing aft
