Brief Description: Countersinking trailing edge wedges and priming
Machine countersunk both trailing edge wedges using drill press. Used edge rolling tool to put slight bend in trailing edges of both elevator skins. scuffed areas inside of skins to allow proper bonding of foam ribs. After masking off rib locations on skin cleaned and primed all parts.
