Greg's Bearhawk Build
Date:  3-20-2016
Number of Hours:  6.00
Brief Description:  Top of panel
Drilled and cleco'd center panel of dash to strenthen it a bit. Previous bulder had plans to use screws up there on the corners for behind the panel access, but I'm going to use a hinged panel so I won't need that. Going with rivets instead. Also cut out naca ducts for front seat ventilation, and while I had them off the plane, trimmed up some places that would have rubbed. Cleaned up all the edges, deburred them and took off all that damn plastic.
top of panel
top of panel
aligned with top of door
