Greg's Bearhawk Build
Date:  2-14-2017
Number of Hours:  6.00
Brief Description:  lots of little things
Re did the fuel line from the left tank that will feed the header tank. I want to keep it as high as possible to feed the header tank. Fixed the old fuel selector hole. Changed out a lot of AN-3 bolts with the proper clevis bolts with cotter pins. I found that the old cotter pins that the previous builder had, had in time hardened, and made them very difficult to install. I ended up using mine. Replaced some AN bolts that didn't have sufficient length. Cleaned off the white plastic shit on the last piece of the floor. I used the new heat gun set at 600 degrees to help. Glad to be done with that crap.
Old fuel selector hole
