Sanded as many as the weld areas that had burned the paint away and started rusting. I could reach most of the lower ones, and when I get the fuselage mounted on the rotiserie I will hit the rest. Then primed them. Got some paint mixed to match the color of the frame as close as possible, and I'll hit those next. Removed the prop. Next the engine will have to come off so I can mount the frame on the rotisserie.
