After sitting for so long, the push tubes for the trim tabs became a little rusty. So I took the right one and removed the rust, cleaned it, taped over the sections that actually make contact with the support brackes, and primed it. Then I put some grease on the previously taped off sections and re installed it. Do the other one next time. Now that I'm moved into the hangar, and most of the little moving in projects are done, I should be able to start making progress again.
