Brief Description: More film removal and left side cargo floor skin w
Cleaned up hangar. Still don't have the baffle on the bottom of the big door, so leaves and crap blows in. Then I started removing the film from the bottom of the skin below the left and right seats. Went a little better this time as I had the technique down. Soak towels in Xylene, put them over the skin and let them sit for 15 minutes, then heat from below and use a razor blade to peel up the film. Unfortunately, my heat gun gave up the ghost towards the end. Luckily, I was almost done. After that, I decided I didn't like the edge of the left cargo floor skin not quite overlapping the side tube. So, just like the right floor skin, I re cut and drilled all the holes. I didn't drill the holes to the final size, or dimple yet. Next time.
