Brought some MEK and some rags and I went to work cleaning 10 plus years of dust and dirt off the fuselage frame. Then I started with the skins, and figuring out where they went. I got most of them in place, and then I started correcting some stuff. Mostly cosmetic, and the right cargo floor skin was where I started. The edge distance for the right side screw holes was not acceptable, so luckily there was plenty of overlap and I was able to recut the right side, and redrill and dimple the screw holes and the cargo tie down holes. I deburred the edges and then started removing the plastic sheet on the bottom side. No luck. I tried MEK, heat and a razor blade and was only able to remove about 5% in 45 minutes of work. That pretty much sucked. So, I've decided to leave the film on the bottom of the cargo floor skin. Can't see it from where I'll be sitting.
