Fixing the Fuel Inlet Cover is a bit of a challenge. I did this by making some 60mm alli into a “U” shape then fixing an anchor not to it. This was then Bonded on to the inlet in the correct position and after Cure I cover with 2 Ply’s of Bid. Work out OK.
